I add a new metric to telegraf and also create a dashboard for display.
Is it possible to view the new metric in the host page together with the default metrics of charts, e.g., cpu, disk, mem?
@samson-wang That requires a pre-canned dashboard. There are instructions for creating new ones, as well as a list of the current ones, in that link. Are you using a pre-existing telegraf plugin, or have you made one of your own?
I made one by using inputs.exec
. I’ll check the pre-canned dashboard. Thanks for the tip.
