I’m new to telegraf, and I try to find a way to rename specific tags to the same name, and add the original tag as a part of the value of the new tag, like:
input
agent_host="hostA"
agent_ip="10.10.10.1"
after regex
aggregated="agent_host:hostA"
aggregated="agent_ip:10.10.10.1"
The reason why I’d do this is I found no way to push raw output as text with outputs.cloudwatch_logs. If there is a known way, please, stop me doing this now ![]()
I’d like to do something like the following below. My question: is there a way to do this tag name: value concatenation for the replacement, please?
[[processors.regex]]
[[processors.regex.tags]]
key ="agent_host"
pattern = '^(?P<agent_host.+>)\=.+$'
replacement = agent_host+':'+${agent_host}
result_key = "aggregated"
