Hello @Anaisdg,
Thank you very much for that suggestion, I did give it a whirl but I am stumbling somewhere. Here are the gory details.
Here we go. I would appreciate any pointers on where I am messing up.
Further the way I am calling processors.execd is it going to be executed only for the inputs.cpu or every possible inputs?
b1scu1t
ps: for anybody else reading this and plan to use python, please look into the line-protocol-parser · PyPI package, once I figure out my issues with execd I plan to use that to.
I test my configs and it looks good.
telegraf --config telegraf.conf --test
2021-04-24T15:24:36Z I! Starting Telegraf 1.18.1
2021-04-24T15:24:36Z I! [processors.execd] Starting process: python3 [cpu.py]
> cpu,host=storage cpu0_usage_active=0,cpu0_usage_guest=0,cpu0_usage_guest_nice=0,cpu0_usage_idle=100,cpu0_usage_iowait=0,cpu0_usage_irq=0,cpu0_usage_nice=0,cpu0_usage_softirq=0,cpu0_usage_steal=0,cpu0_usage_system=0,cpu0_usage_user=0,cpu1_usage_active=0,cpu1_usage_guest=0,cpu1_usage_guest_nice=0,cpu1_usage_idle=100,cpu1_usage_iowait=0,cpu1_usage_irq=0,cpu1_usage_nice=0,cpu1_usage_softirq=0,cpu1_usage_steal=0,cpu1_usage_system=0,cpu1_usage_user=0,cpu2_usage_active=1.960784293136852,cpu2_usage_guest=0,cpu2_usage_guest_nice=0,cpu2_usage_idle=98.03921570686315,cpu2_usage_iowait=0,cpu2_usage_irq=0,cpu2_usage_nice=0,cpu2_usage_softirq=0,cpu2_usage_steal=0,cpu2_usage_system=0,cpu2_usage_user=1.9607843141800627,cpu3_usage_active=4.00000000372529,cpu3_usage_guest=0,cpu3_usage_guest_nice=0,cpu3_usage_idle=95.99999999627471,cpu3_usage_iowait=0,cpu3_usage_irq=0,cpu3_usage_nice=0,cpu3_usage_softirq=0,cpu3_usage_steal=0,cpu3_usage_system=0,cpu3_usage_user=4.0000000000873115 1619277877000000000
2021-04-24T15:24:37Z I! [processors.execd] Process /usr/bin/python3 shut down
And now when I actually run it, it just sits there.
2021-04-24T15:25:06Z I! Starting Telegraf 1.18.1
2021-04-24T15:25:06Z I! Loaded inputs: cpu
2021-04-24T15:25:06Z I! Loaded aggregators:
2021-04-24T15:25:06Z I! Loaded processors: execd
2021-04-24T15:25:06Z I! Loaded outputs: file
2021-04-24T15:25:06Z I! Tags enabled: host=storage
2021-04-24T15:25:06Z I! [agent] Config: Interval:2s, Quiet:false, Hostname:"storage", Flush Interval:1s
2021-04-24T15:25:06Z I! [processors.execd] Starting process: python3 [cpu.py]
telegraf.conf
[global_tags]
[agent]
interval = "2s"
round_interval = true
metric_batch_size = 1000
metric_buffer_limit = 1000
collection_jitter = "0s"
flush_interval = "1s"
flush_jitter = "0s"
precision = ""
debug = false
hostname = ""
omit_hostname = false
##[[inputs.system]]
# Read metrics about cpu usage
[[inputs.cpu]]
## Whether to report per-cpu stats or not
percpu = true
## Whether to report total system cpu stats or not
totalcpu = false
## If true, collect raw CPU time metrics
collect_cpu_time = false
## If true, compute and report the sum of all non-idle CPU states
report_active = true
[[processors.execd]]
command = ["python3","cpu.py"]
[[outputs.file]]
splunkmetric_multimetric = true
splunkmetric_hec_routing = true
data_format = "influx"
files = ["stdout"]
cpu.py
import sys
def main():
final_metrics_dict = dict()
for line in sys.stdin:
header_list = line.rstrip().split(" ")[0].split(",")
metrics_list = line.rstrip().split(" ")[1].split(",")
footer = line.rstrip().split(" ")[2]
metric_name = header_list[0]
dimensions_dict = dict(s.split("=") for s in header_list[1:])
metrics_dict = dict(s.split("=") for s in metrics_list)
cpuid = dimensions_dict['cpu']
dimensions_dict.pop('cpu')
for k,v in metrics_dict.items():
new_key = cpuid + "_" + k
metrics_dict[new_key] = metrics_dict.pop(k)
final_metrics_dict.update(metrics_dict)
results = ''
results = results + metric_name + ','
for k,v in dimensions_dict.items():
results = results + k + '=' + v + ','
results = results + ' '
for k,v in final_metrics_dict.items():
results = results + ' ' + footer
results = results.replace(', ', ' ')
print(results)
sys.stdout.flush()
if __name__ == '__main__':
main()
