I’m using telegraf as a receiver for Cisco Telemetry data, the metrics I get back are all working fine, but I would like to trim the “phy_info/phy_details/” in front of the fields.
At the moment I’m using the “rename processor”:
[[processors.rename.replace]]
field = "phy_info/phy_details/dig_opt_mon_alarm_thresholds/transceiver_voltage_warning_high"
dest = "dig_opt_mon_alarm_thresholds/transceiver_voltage_warning_high"
field = "phy_info/phy_details/dig_opt_mon_alarm_thresholds/transceiver_voltage_warning_low"
dest = "dig_opt_mon_alarm_thresholds/transceiver_voltage_warning_low"
field = "phy_info/phy_details/dig_opt_mon_alarm_thresholds/transceiver_voltage_alarm_low"
dest = "dig_opt_mon_alarm_thresholds/transceiver_voltage_alarm_low"
Is there a better way to do this?
I’ll be getting more Telemetry data and adding a rename processor for every field seems like its not the best way.
Thanks in advance !
_
Example Data for the Telemetry:
media-if,host=ti-p-telinput3,interface-name=MgmtEth0/RSP1/CPU0/1,path=Cisco-IOS-XR-drivers-media-eth-oper:ethernet-interface/interfaces/interface,source=NAME,subscription=media,tag_kafkatopic=telemetry_influx layer1_info/autoneg/mask=0i,oper_state_up=0i,phy_info/media_type="ethernet-1000base-thd",phy_info/phy_details/vendor_serial_number="",layer1_info/current_alarms/squelch_alarm="alarm-not-supported",layer1_info/ipg="standard",layer1_info/duplex="half-duplex",layer1_info/current_alarms/loss_of_synchronization_data_alarm="alarm-not-supported",mac_info/burned_in_mac_address="xxxx.xxxx.xxxx",phy_info/phy_details/vendor_part_number="",layer1_info/led_state="led-off",layer1_info/autoneg/config_override=0i,layer1_info/current_alarms/sd_ber_alarm="alarm-not-supported",layer1_info/opd_monitoring/settings/received_optical_power_degrade_threshold_set=0i,layer1_info/link_state="phy-not-present",layer1_info/previous_alarms/pcs_loss_of_block_lock_alarm="alarm-not-supported",layer1_info/opd_monitoring/settings/received_optical_power_degrade_threshold=51i,admin_state="disabled",phy_info/phy_details/lane_field_validity/wavelength_valid=0i,phy_info/phy_details/lane_field_validity/receive_power_valid=0i,layer1_info/speed="ten-mbps",layer1_info/previous_alarms/local_fault_alarm="alarm-not-supported",mac_info/mru=1510i,phy_info/phy_details/lane_field_validity/transmit_power_valid=0i,phy_info/phy_details/optics_type="",layer1_info/opd_monitoring/supported=1i,phy_info/phy_details/vendor="",phy_info/phy_details/revision_number="",layer1_info/current_alarms/hi_ber_alarm="alarm-not-supported",layer1_info/previous_alarms/sf_ber_alarm="alarm-not-supported",layer1_info/previous_alarms/hi_ber_alarm="alarm-not-supported",layer1_info/previous_alarms/squelch_alarm="alarm-not-supported",layer1_info/current_alarms/pcs_loss_of_block_lock_alarm="alarm-not-supported",layer1_info/previous_alarms/rx_opd_alarm="alarm-not-supported",mac_info/mtu=1510i,phy_info/loopback="no-loopback",layer1_info/current_alarms/received_loss_of_signal_alarm="alarm-not-supported",phy_info/phy_present="phy-not-present",layer1_info/current_alarms/local_fault_alarm="alarm-not-supported",mac_info/multicast_mac_filters/multicast_promiscuous=0i,layer1_info/autoneg/speed="one-gbps",mac_info/operational_mac_address/value="78ba.f977.fb01",layer1_info/flowcontrol="no-flowcontrol",layer1_info/previous_alarms/sd_ber_alarm="alarm-not-supported",layer1_info/previous_alarms/loss_of_synchronization_data_alarm="alarm-not-supported",phy_info/phy_details/lane_field_validity/laser_bias_valid=0i,layer1_info/current_alarms/sf_ber_alarm="alarm-not-supported",layer1_info/current_alarms/rx_opd_alarm="alarm-not-supported",layer1_info/current_alarms/remote_fault_alarm="alarm-not-supported",layer1_info/previous_alarms/received_loss_of_signal_alarm="alarm-not-supported",layer1_info/autoneg/autoneg_enabled=1i,layer1_info/autoneg/flowcontrol="no-flowcontrol",layer1_info/autoneg/fec="not-configured",layer1_info/autoneg/duplex="full-duplex",layer1_info/previous_alarms/remote_fault_alarm="alarm-not-supported" 1571047263986000000
