About chrongraf organizations
I’m trying to use chrongraf version 1.4 which is supposed to have support for organizations. But I can’t see any org related option in the UI. Is there some config that needs to be enabled? I’m using the community edition.
Samit
Same for me, not possible to see Chronograf in “crown icon”, I only have Admin in crown icon
The orgs started to work for me when I integrated chonograf with Okta oauth provider. I guess you need to integrate it with an oauth provider for it to work
