Hello ![]()
I’m trying to login to chronograf via OAuth but getting still the same error. Currently github but I got the same issue for different providers as well. (gitlab, google)
Error:
This Chronograf is private. To gain access, you must be explicitly added by an administrator
Can I have advice on how to solve the issue? What does it mean that the user has to be “explicitly added by an administrator”?
Full logs:
Jun 11 21:59:51 server chronograf[18016]: time=“2019-06-11T21:59:51+02:00” level=info msg=“Response: OK” component=server method=GET remote_addr=“192.168.1.101:57160” response_time=“281.864µs” status=200
Jun 11 21:59:51 server chronograf[18016]: time=“2019-06-11T21:59:51+02:00” level=error msg=“Error message This Chronograf is private. To gain access, you must be explicitly added by an administrator.” component=server http_status =403
Jun 11 21:59:51 server chronograf[18016]: time=“2019-06-11T21:59:51+02:00” level=info msg=“Response: Forbidden” component=server method=GET remote_addr=“192.168.1.101:57160” response_time=“378.809µs” status=403
Jun 11 21:59:52 server chronograf[18016]: time=“2019-06-11T21:59:52+02:00” level=info msg=“Response: Temporary Redirect” component=server method=GET remote_addr=“192.168.1.101:57160” response_time=“123.077µs” status=307
Jun 11 21:59:53 server chronograf[18016]: time=“2019-06-11T21:59:53+02:00” level=info msg=“found an extra id_token, but option --useidtoken is not set” component=auth method=GET remote_addr=“192.168.1.101:57160” url=/oauth/github/callback?code=85125105c13d0
Jun 11 21:59:53 server chronograf[18016]: time=“2019-06-11T21:59:53+02:00” level=info msg=“User some_name@gmail.com is authenticated” component=auth method=GET remote_addr=“192.168.1.101:57160” url=/oauth/github/callback?code=85125105c13d0023a4cb&state=ey
Jun 11 21:59:53 server chronograf[18016]: time=“2019-06-11T21:59:53+02:00” level=info msg=“Response: Temporary Redirect” component=server method=GET remote_addr=“192.168.1.101:57160” response_time=778.312799ms status=307
Jun 11 21:59:54 server chronograf[18016]: time=“2019-06-11T21:59:54+02:00” level=info msg=“Response: OK” component=server method=GET remote_addr=“192.168.1.101:57160” response_time=“218.808µs” status=200
Jun 11 21:59:54 server chronograf[18016]: time=“2019-06-11T21:59:54+02:00” level=error msg=“Error message This Chronograf is private. To gain access, you must be explicitly added by an administrator.” component=server http_status =403
Jun 11 21:59:54 server chronograf[18016]: time=“2019-06-11T21:59:54+02:00” level=info msg=“Response: Forbidden” component=server method=GET remote_addr=“192.168.1.101:57160” response_time=“379.014µs” status=403
Chronograf ENV:
TLS_CERTIFICATE=/etc/letsencrypt/live/example.eu/fullchain.pem
TLS_PRIVATE_KEY=/etc/letsencrypt/live/example.eu/privkey.pem
BOLT_PATH=/var/lib/chronograf/chronograf-v1.db
GH_CLIENT_ID=d398n20fj04jff4f4
GH_CLIENT_SECRET=hc9843hv9f8h498gh9hg4
GH_ORGS=my-org
CANNED_PATH=/usr/share/chronograf/canned
TOKEN_SECRET=hf904h3f09h43
