I am having hard time understanding the problem
I am able to ingest the data properly but unable to query it back initially i assumed maybe the version issue but for a different measurement withing the same bucket it is working
Any help is appreciated! Thanks [Will attach another image in the msg]
Hello @shanmukh-d,
What client library are you using?
And what version of InfluxDB are you using? If you go to the homepage you can see the version on the bottom right.
