Command: influx user create -n root -o test-com
Return: Error: failed to lookup org with name “test-com”: 403 Forbidden: User is inactive
→ Create a user in InfluxDB | InfluxDB OSS 2.3 Documentation
Why? Thx for feedback(s)…
Regards, Hans
Regards, Hans
Same with that commmand:
root@xili:~# influx user list
Error: failed to list users: 403 Forbidden: User is inactive
I deleted it before with " ```
influx user delete -i
Is it REALLY delete or just inactive?
Hello @ugvsffzawv,
The
influx user deletecommand deletes users from InfluxDB OSS 2.x , but does not delete users from InfluxDB Cloud . For information about removing a user from your InfluxDB Cloud organization, see
Are you using OSS?
Then it will delete it.
I’m surprised you can see the status with influx users list, I only get the following:
ID Name
09acee5bf5042000 Anais
09d4b1cc89df7000 johndoe
09d4b1f40cdf7000 johndoe1
I only see the status when I use influx org members list and I get:
ID Name User Type Status
09d4b1cc89df7000 johndoe member active
09d4b1f40cdf7000 johndoe1 member active
So it does look like the master member isn’t considered a member but the main user.
I can see how you’re getting the Error: failed to list users but not the rest of the error message. That error doesn’t exist anywhere in the code.
There’s only: https://github.com/influxdata/influx-cli/blob/adc58b844139e39541f840974ee88b898d00f6ad/clients/user/user.go#L89
I have no problems deleting my members either.
What version of InfluxDB and CLI are you using?
Maybe try upgrading your CLI?
Yes, i’m using the OSS version. Now i’ve done a reinstallation - will look it will solve the problem or not.
Best regards, Hans
