I’m collecting certificate information from a few different domains and realise the start and expiry dates are in unix/epoch time.
I know there is a function in Kapacitor to turn a timestamp into a unix timestamp, but is there a function or method to convert unix timestamp to a human readable format?
There are 4 fields, all integers.
startdate = epoch time
age = stored in seconds
expiry = stored in seconds
enddate = epoch time
I plan to convert expiry into days using a TICK Script so i can trigger an alert when the cert has <30 days to expiration. What i would like to do though is convert the two unix timestamps into a human readable format i can use in my alert messages.
Can this be done with TICK/Kapacitor?
Kapacitor 1.5.2.
InfluxDB: all servers runnning 1.5.2 EXCEPT for one, which is running influxdb 1.8.3
If you use 1.8 then yes Kapacitor will still work.
Enabling flux should not impact any existing CQs
You can run Flux alongside InfluxQL with 1.x. And this feature is in the works for 2.x.
Thanks @Anaisdg I’ll do some research and testing. Its more of a would be nice to have than a requirement. As long as i can display the days til expiry i can work with that.I just thought i’d pretty up the data a little bit for the guys getting the alerts.
