Dear sir,
I’m reading from Modbus registers and writing the data every 10 seconds to a csv file.
I set the file rotation to every minute, and it works but something strange happens: the header file disappears (it’s only there for the first file).
Here the configuration
[[outputs.file]]
files = ["bb_1/plc_data.csv"]
data_format = "csv"
csv_separator = ";"
csv_header = true
csv_timestamp_format = "2006-01-02T15:04:05"
rotation_interval = "1m"
rotation_max_size = "0MB"
rotation_max_archives = -1
[outputs.file.tagpass]
source = ["bb_1"]
There are several plcs, each with a tag, and that’s why there is the tagpass section, to write files in a folder for each plc.
Thank you,
best regards
