I encountered an issue while attempting to ingest records into InfluxDB 2.7.4 using the Java Client Library version 6.6.0. Despite using a POJO and its corresponding class for data writing, I am unable to successfully ingest records.
Specifically, I am trying to set a custom timestamp (e.g., “2023-12-13T07:20:23.021Z”) in the _time column, but for some reason, the current timestamp is being stored in the _time column when writing the data.
@Measurement(name = “temperature”)
public class Temperature {
@Column(tag = true)
String location;
@Column
Double value;
@Column(timestamp = true)
Instant time;
//getters and setters
And the code snippet for writing the data:
WriteApiBlocking writeApi = influxDBClient.getWriteApiBlocking();
Temperature temperature = new Temperature();
temperature.setLocation(“south”);
temperature.setValue(62D);
temperature.setTime(Instant.parse(“2023-12-13T07:20:23.021Z”));
writeApi.writeMeasurement(WritePrecision.NS, temperature);
influxDBClient.close();
I would appreciate any insights or assistance in resolving this timestamp issue. Thank you!
