Writin to Influx problem
Hello. I’m using Influx to write CAN datas from S3 server. For last 4-5 days, i’m not able to run the bat, it gives the error attached. Can anyone tell something about what causes this?
Thanks.
Anything else changed recently?
If this is influxdb 2.x, Can you login to the web interface ?
Is the server hosting influxdb all healthy? Maybe try a reboot if in doubt
