I am using Labview to communicate with influxDB and found a problem that cannot pass writing multiple test points.
wirte 5 points to TDMS1 measurements,but when i select from the tdms1,the result only 1
PS: the influxdb 1.2
Hello @degent007,
Welcome! Can you please share how you’re querying influxdb? Can you also share the influxdb logs at time of write? Is a curl successful?
Thank you.
