Hello, I want to properly transfer the data in the following XML structure obtained from Wowza Streaming Engine (http://localhost:8080/connectioncounts.xml) to InfluxDB using Telegraf, Golang, or any other method and visualize it in Grafana. However, I have not been successful in any way. I don’t have any knowledge of Golang like the article Monitor Icecast and Wowza listeners with dockerized InfluxDB, Grafana and Go | by Peter | Medium, which was prepared 8 years ago.
Is there anyone who can help?"
[The provided XML data is below.]
<WowzaStreamingEngine>
<ConnectionsCurrent>0</ConnectionsCurrent>
<ConnectionsTotal>0</ConnectionsTotal>
<ConnectionsTotalAccepted>0</ConnectionsTotalAccepted>
<ConnectionsTotalRejected>0</ConnectionsTotalRejected>
<MessagesInBytesRate>158255.0</MessagesInBytesRate>
<MessagesOutBytesRate>0.0</MessagesOutBytesRate>
<VHost>
<Name>_defaultVHost_</Name>
<TimeRunning>58836.737</TimeRunning>
<ConnectionsLimit>0</ConnectionsLimit>
<MessagesInBytesRate>158165.0</MessagesInBytesRate>
<Application>
<Name>live</Name>
<Status>loaded</Status>
<TimeRunning>58835.252</TimeRunning>
<MessagesInBytesRate>171547.0</MessagesInBytesRate>
<ApplicationInstance>
<Name>_definst_</Name>
<TimeRunning>58835.194</TimeRunning>
<MessagesInBytesRate>170777.0</MessagesInBytesRate>
<Stream>
<Name>KafaRadyo.stream</Name>
<SessionsFlash>0</SessionsFlash>
<SessionsCupertino>0</SessionsCupertino>
<SessionsSanJose>0</SessionsSanJose>
<SessionsSmooth>0</SessionsSmooth>
<SessionsRTSP>0</SessionsRTSP>
<SessionsWebRTC>0</SessionsWebRTC>
<SessionsMPEGDash>0</SessionsMPEGDash>
<SessionsTotal>0</SessionsTotal>
</Stream>
<Stream>
<Name>PowerFM.stream</Name>
</Stream>
<Stream>
</ApplicationInstance>
</Application>
</VHost>
</WowzaStreamingEngine>
Hello @aydinyildirim73,
Have you taken a look at this tutorial?
I think its a great place to start.
Parsing it depends on what you want the output to be.
Also @jpowers might be able to help you here.
Thank you!!
Agreed with @Anaisdg. Take a look at that tutorial around the use of the xml parser. The big question to ask is what tags and fields you want to capture from that xml and then develop the parser settings to pull those out!
If you gave an example of the output you are trying to achieve that might help and what you have tried so far, we could possible provide some guidance.
Finally, I found solution. Thanks to ChatGPT
Here my golang solution, I hope It helps someone
package main
import (
"encoding/xml"
"fmt"
"io/ioutil"
"net/http"
"strings"
"time"
type Stream struct {
Name string `xml:"Name"`
SessionsTotal int `xml:"SessionsTotal"`
type ApplicationInstance struct {
Streams []Stream `xml:"Stream"`
type Application struct {
ApplicationInstance ApplicationInstance `xml:"ApplicationInstance"`
type VHost struct {
ConnectionsCurrent int `xml:"ConnectionsCurrent"`
ConnectionsTotal int `xml:"ConnectionsTotal"`
Application []Application `xml:"Application"`
type WowzaData struct {
VHost VHost `xml:"VHost"`
func main() {
// my wowza server ip
url := "http://10.35.224.39:8086/connectioncounts"
resp, err := http.Get(url)
if err != nil {
fmt.Println("HTTP request error:", err)
return
defer resp.Body.Close()
xmlData, err := ioutil.ReadAll(resp.Body)
if err != nil {
fmt.Println("XML read error:", err)
return
var result WowzaData
err = xml.Unmarshal(xmlData, &result)
if err != nil {
fmt.Println("XML error:", err)
return
// InfluxDB database
org := "myOrganization"
bucket := "wowzatest"
token := "VYOPqXrLtd5CqrvLXNVv9XUaKeMH4IphjdSFFi_6BffslQuu2JpSr94SlA4JZJCGDPq4ibH7IyG3IORq03bThQ=x"
//my local server ip
influxURL := "http://10.35.224.39:9086"
influxEndpoint := fmt.Sprintf("%s/api/v2/write?org=%s&bucket=%s&precision=ns", influxURL, org, bucket)
req, err := http.NewRequest("POST", influxEndpoint, nil)
if err != nil {
return
req.Header.Set("Authorization", "Token "+token)
req.Header.Set("Content-Type", "text/plain")
vhost := result.VHost
client := &http.Client{Timeout: 10 * time.Second}
for _, app := range vhost.Application {
instance := app.ApplicationInstance
for _, stream := range instance.Streams {
dataStream := fmt.Sprintf("wowza_stream_stats,stream_name=%s SessionsTotal=%d", stream.Name, stream.SessionsTotal)
reqStream := ioutil.NopCloser(strings.NewReader(dataStream))
req.Body = reqStream
resp, err = client.Do(req)
if err != nil {
fmt.Println("Error to send InfluxDB:", err)
return
fmt.Println("Successfully send to InfluxDB")
Here, my sample XML output from wowza server
<ConnectionsCurrent>1</ConnectionsCurrent>
<ConnectionsTotal>1</ConnectionsTotal>
<ConnectionsTotalAccepted>1</ConnectionsTotalAccepted>
<MessagesInBytesRate>258767.0</MessagesInBytesRate>
<MessagesOutBytesRate>16651.0</MessagesOutBytesRate>
<VHost>
<TimeRunning>430507.262</TimeRunning>
<Application>
<Name>live</Name>
<TimeRunning>430506.524</TimeRunning>
<MessagesInBytesRate>259457.0</MessagesInBytesRate>
<TimeRunning>430506.492</TimeRunning>
<MessagesInBytesRate>253438.0</MessagesInBytesRate>
<MessagesOutBytesRate>16654.0</MessagesOutBytesRate>
<Stream>
<SessionsTotal>3</SessionsTotal>
</Stream>
<Stream>
<Name>RadyoNostalji.stream</Name>
<SessionsTotal>2</SessionsTotal>
</Stream>
</Application>
</VHost>
