<root>
<measEntity localDn="VNFID=bangloreiit-5005cucp1; gNBID=5005; gNBName=;" swVersion="6.0.00.49.6"/>
<measData>
<measInfo measInfoId="OR.end">
<granPeriod duration="PT300S" endTime="2021-07-02T17:10:00+00:00"/>
<measTypes>SgnbAddAttemptCell.enb.0 SgnbAddAttemptCell.enb.1 SgnbAddAttemptCell.enb.2 SgnbAddAttemptCell.enb.3</measTypes>
<measResults>0 0 0 0</measResults>
</measInfo>
</measData>
</root>
Above is my xml data format. I wanted to parse it using telegraf. I am able to get measurement, but currently i am facing 2 challenges:
To get Tag name - measEntity will provide tag name; eg - tag VNFID with value bangaloreiit-5005cucp1 and so on. But i am not able to get the tags.
Field name - Using measTypes i want to get the fieldnames which are separated by space- eg - SgnbAddAttemptCell.enb.0, SgnbAddAttemptCell.enb.1 and so on and their respective values inside measResults portion.
Can someone help me out here. I am referring the following link for reference - How to Parse Your XML Data with Telegraf | InfluxData
I think that example is not valid xml because some closing tags are missing?
I pasted small portion from large xml file, hence missed ending part. Now i have updated it.
In my opinion, the XML data is very poorly structured. I don’t know where the XML data comes from, but I would first try to solve the problem at the source and make sure that better structured XML data is delivered.
Otherwise it will be a difficult task to parse the XML data. For meastypes and measResults you will need a custom processors.execd script to split that up. I don’t think this is possible with the xml parser alone.
This could be a starting point. However, in my opinion, the fields cannot be parsed with the xml parser alone in the way you want it.
[[inputs.file]]
name_override = "xml"
files = ["xmlparser.xml"]
data_format = "xml"
[[inputs.file.xml]]
[inputs.file.xml.tags]
name = "substring-after(substring-before(/root/measEntity/@localDn, ';'), '=')"
[inputs.file.xml.fields]
measTypes = "string(/root/measData/measInfo/measTypes)"
measResults = "string(/root/measData/measInfo/measResults)"
[[outputs.file]] # only for debugging
files = ["xmlparser.out"]
influx_sort_fields = true
This is a solution with a processors.execd script in Python.
See below, first the Telegraf config and then the python script.
[[inputs.file]]
data_format = "xml"
[[inputs.file.xml]]
[[processors.execd]]
namepass = ["xml"]
command = ["python", "xmlparser.py"]
from influxdb_client import Point
from line_protocol_parser import parse_line
while True:
try:
input_line = input() # read from stdin
except EOFError: # catch EOF error
break
except KeyboardInterrupt: # catch KeyboardInterrupt
break
else:
data = parse_line(input_line) # parse input line
measTypes = data['fields'].get('measTypes')
measResults = data['fields'].get('measResults')
if measTypes and measResults:
measTypesList = measTypes.strip().split()
measResultsList = measResults.strip().split()
if len(measTypesList) == len(measResultsList):
for i in range(len(measTypesList)):
data['fields'].update({measTypesList[i]: int(measResultsList[i])}) # update field
# drop original fields
data['fields'].pop('measTypes')
data['fields'].pop('measResults')
point = Point.from_dict(data) # metric from dict
print(point.to_line_protocol()) # write to stdout
And here is a solution with a processors.execd plugin in Go.
See below, first the Telegraf config and then the Go program.
[[inputs.file]]
data_format = "xml"
[[inputs.file.xml]]
namepass = ["xml"]
command = ["xmlparser.exe"] # compiled go file
package main
import (
"fmt"
"os"
"strconv"
"strings"
"github.com/influxdata/telegraf/plugins/parsers/influx"
"github.com/influxdata/telegraf/plugins/serializers"
var measTypesList []string
var measResultsList []string
func main() {
parser := influx.NewStreamParser(os.Stdin)
serializer, _ := serializers.NewInfluxSerializer()
for {
metric, err := parser.Next()
if err != nil {
if err == influx.EOF {
return // stream ended
if parseErr, isParseError := err.(*influx.ParseError); isParseError {
fmt.Fprintf(os.Stderr, "parse ERR %v\n", parseErr)
os.Exit(1)
fmt.Fprintf(os.Stderr, "ERR %v\n", err)
os.Exit(1)
measTypes, err1 := metric.GetField("measTypes")
measResults, err2 := metric.GetField("measResults")
if err1 && err2 {
measTypesList = strings.Fields(fmt.Sprintf("%s", measTypes))
measResultsList = strings.Fields(fmt.Sprintf("%s", measResults))
if len(measTypesList) == len(measResultsList) {
for i := 0; i < len(measTypesList); i++ {
intValue, err3 := strconv.Atoi(measResultsList[i])
if err3 == nil {
metric.AddField(measTypesList[i], intValue)
} else {
fmt.Fprintf(os.Stderr, "ERR %v\n", err3)
os.Exit(1)
metric.RemoveField("measTypes") // drop original fields
metric.RemoveField("measResults") // drop original fields
out, err4 := serializer.Serialize(metric)
if err4 != nil {
fmt.Fprintf(os.Stderr, "ERR %v\n", err4)
os.Exit(1)
fmt.Fprint(os.Stdout, string(out))
measTypesList = nil // clear array
measResultsList = nil // clear array
