WITH MEASUREMENTS clause returns no results when named measurement is clearly there
I can’t figure out why my “WITH MEASUREMENT” clause is not working.
Very simple example:
This works:
SHOW MEASUREMENTS
When I add filter I get no results
SHOW MEASUREMENTS WITH MEASUREMENT = "binary_sensor"
I tried a regex filter and still no luck
SHOW MEASUREMENTS WITH MEASUREMENT =~ /binary.*/
I’m using the web based Data Explorer tool on cloud2.influxdata.com. I tried the same query from a Grafana visualization editor and got the same results (data shows with no filter, but adding a filter yields no results).
I’m trying to make the switch from Flux to InfluxQL since they are dropping long term support for flux.
TIA
Can you just query it directly to check if data is there: SELECT * FROM "binary_sensor" LIMIT 1
That does return data, yes.
According the examples and according to the data explorer “Measurement” options (screenshot below), I should get one record. I eventually want to use regex to explore my schema but figured I’d test with a simple measurement name I know for a fact is there…and yet, I’m not getting the one expected result. I dug into this for hours and I’m pretty familiar (apparently not enough though) w influx, but this one has me stumped.
Any obvious misses?
TIA
