Ich weiss nicht weiter was muss ich machen damit INFLUX 3 läuft???
Kappier das nicht wie geht das???
influxdb3 create token --admin
Failed to create token, error: RequestSend { method: POST, url: “http://127.0.0.1:8181/api/v3/configure/token/admin”, source: reqwest::Error { kind: Request, url: Url { scheme: “http”, cannot_be_a_base: false, username: “”, password: None, host: Some(Ipv4(127.0.0.1)), port: Some(8181), path: “/api/v3/configure/token/admin”, query: None, fragment: None }, source: hyper::Error(Connect, ConnectError(“tcp connect error”, Os { code: 111, kind: ConnectionRefused, message: “Connection refused” })) } }HELP HELP ???
Pooh
2
Is “reqwest” a copy/paste error, or is that the problem?
Antony.
Try to make sure server is running, you can do so by typing curl http://127.0.0.1:8181/health
