I want to calculate electricity cost per hour. Because electricity prices vary by hour, I use map and date.hour function to multiply cost by dynamic price.
The query below takes 16 seconds:
import "date"
from(bucket: "energy")
|> filter(fn: (r) => r["_measurement"] == "electricity")
|> filter(fn: (r) => r["_field"] == "usage")
|> aggregateWindow(every: 1h, fn: last, createEmpty: false, timeSrc: "_start")
|> difference()
|> map(fn: (r) => ({r with _value: if date.hour(t: r._time) > 9 then r._value * 0.54 else r._value * 0.87}))
Same time range, but replace date.hour with r._value. The query below only takes 1.6 seconds:
|> difference()
|> map(fn: (r) => ({r with _value: if r._value > 9 then r._value * 0.54 else r._value * 0.87}))
The date operation is 10x slower than raw query.
