Yeah, I can confirm that: nothing changes in the results data while using start: -duration(v: int(v: task.every) * 2) or start: -task.every.
I made a test and would like to share the results, for anyone interested (now or in the future). Sorry for the long post but I think it might be useful!
Bash script to create sample data
I created a bash script that inserts an integer value that is incremented every time the script is run, in this way:
#!/bin/bash
# Set the InfluxDB host, port, and token
INFLUXDB_HOST="192.168.10.2"
INFLUXDB_PORT="8086"
INFLUXDB_ORG="org"
INFLUXDB_BUCKET="sample"
INFLUXDB_TOKEN="==replace=with=yours=="
# Read the current variable value (latest one)
cval=$(/sbin/curl -s \
"http://$INFLUXDB_HOST:$INFLUXDB_PORT/api/v2/query?org=$INFLUXDB_ORG" \
--header "Authorization: Token $INFLUXDB_TOKEN" \
--header "Content-Type: application/vnd.flux" \
--header "Accept: application/csv" \
--data-binary "
from(bucket: \"$INFLUXDB_BUCKET\")
|> range(start: 0)
|> filter(fn: (r) => r[\"_field\"] == \"value\")
|> last()
|> keep(columns: [\"_value\"])
| /bin/awk 'BEGIN { FS=","; RS="\r\n" } /^,_result/{print $4; exit}')
# Print the data
/bin/echo "Current value = |$cval|"
cval=$((cval + 1))
/bin/echo "New value = |$cval|"
# Insert the new data into InfluxDB
/sbin/curl --request POST \
"http://$INFLUXDB_HOST:$INFLUXDB_PORT/api/v2/write?org=$INFLUXDB_ORG&bucket=$INFLUXDB_BUCKET" \
--header "Content-Type: text/plain; charset=utf-8" \
--header "Accept: application/json" \
--data-binary "
test value=$cval
I added a cron line to run this script every 30 minutes (actually at 0 and 30 minutes):
# m h dom m dow cmd
*/30 * * * * /influx-test.sh
InfluxDB task settings
Then I prepared the task in InfluxDB that downsamples the data from the original bucket sample (with the incremental values) into a new one named sample_1h:
// Task settings
option task = {name: "sample_1h", every: 1h, offset: 2m}
// Defines the data source
data =
from(bucket: "sample")
|> range(start: -task.every) // START WITH THIS
//|> range(start: -duration(v: int(v: task.every) * 2)) // THEN THIS
|> filter(fn: (r) => r._field == "value")
// Write aggregated data
data
|> aggregateWindow(fn: mean, every: task.every, createEmpty: false)
|> set(key: "agg_type", value: "mean")
|> to(bucket: "sample_1h", org: "org")
data
|> aggregateWindow(fn: min, every: task.every, createEmpty: false)
|> set(key: "agg_type", value: "min")
data
|> aggregateWindow(fn: max, every: task.every, createEmpty: false)
|> set(key: "agg_type", value: "max")
Results
Simple range
Let’s start with the simple range(start: -task.every), you can query the original database with:
|> range(start: 0)
|> filter(fn: (r) => r["_measurement"] == "test")
|> filter(fn: (r) => r["_field"] == "value")
and these are the results (look ath the one second delay in the _time column, due to the time the Bash script takes to read and reinsert the new value):
_value _time
122 2023-07-22T06:00:01.898Z
123 2023-07-22T06:30:01.740Z
124 2023-07-22T07:00:01.633Z // 1st
125 2023-07-22T07:30:01.388Z // 1st
126 2023-07-22T08:00:01.508Z // 2nd
127 2023-07-22T08:30:01.276Z // 2nd
128 2023-07-22T09:00:01.818Z
Then I queried the downsampled database after the first and second task iteraction, with the following query:
from(bucket: "sample_1h")
|> range(start: 0)
In the first task iteraction, at about 08:03:00.000Z I got:
_value _time agg_type
124 2023-07-22T08:00:00.000Z min // NEW
124.5 2023-07-22T08:00:00.000Z mean // NEW
125 2023-07-22T08:00:00.000Z max // NEW
In the second task iteraction, at 09:11:00.000Z I got:
126 2023-07-22T09:00:00.000Z min // NEW
126.5 2023-07-22T09:00:00.000Z mean // NEW
127 2023-07-22T09:00:00.000Z max // NEW
So everytime the task runs, 3 new lines are added and as the aggregation window is 1 hour (see: aggregateWindow(fn: mean, every: task.every, createEmpty: false) with task.every = 1h in the task) the min/mean/max values are calculated from the previous hour to the current hour.
You can notice that in the first iteraction the max value is 125 because the task runs at 2023-07-22T08:00:00.000Z and in the time window 2023-07-22T07:00:00.000Z - 2023-07-22T08:00:00.000Z (1 hour) 125 is the maximum value, as 126 is recorded 1 second later (at 2023-07-22T08:00:01.508Z).
Doubled duration range
After emptying the start_1h bucket and changing the task above with the double duration, i.e. like so:
data =
and with this data in the sample bucket:
_value _time
128 2023-07-22T09:00:01.818Z // 1st_1
129 2023-07-22T09:30:01.682Z // 1st_1
130 2023-07-22T10:00:01.499Z // 1st_2 / 2nd_1
131 2023-07-22T10:30:01.215Z // 1st_2 / 2nd_1
132 2023-07-22T11:00:01.043Z // 2nd_2
133 2023-07-22T11:30:01.691Z // 2nd_2
these are the results of the first task iteraction, at 11:34:00.000Z
128 2023-07-22T10:00:00.000Z min // NEW
130 2023-07-22T11:00:00.000Z min // NEW
128.5 2023-07-22T10:00:00.000Z mean // NEW
130.5 2023-07-22T11:00:00.000Z mean // NEW
129 2023-07-22T10:00:00.000Z max // NEW
131 2023-07-22T11:00:00.000Z max // NEW
In the second task iteraction, at 12:02:00.000Z I got:
132 2023-07-22T12:00:00.000Z min // NEW
132.5 2023-07-22T12:00:00.000Z mean // NEW
133 2023-07-22T12:00:00.000Z max // NEW
You can spot that the differences apply only in the first run of the task, as doubling the range creates 2 lines for each aggregation, meaning I had 6 new lines. But then, after the second run, always 3 lines are added (or the other 3 are overwritten, as @fercasjr wrote).
Anyway this doesn’t change the results, other that starting from 2 hours before the task first run.
Final considerations and TL;DR
Just stick with the simple:
data =
|> range(start: -task.every) // <-- THAT'S OK!
that is perfect for the goal! Hope this helps.
