When using the input plugin Event hub Consumer to send data to InfluxDB 1.8, ‘bool’ tags are missing.
This is the Telegraf congiguration settings:
[[outputs.file]]
Files to write to, “stdout” is a specially handled file.
files = [“stdout”]
Data format to output.
Each data format has its own unique set of configuration options, read
more about them here:
https://github.com/influxdata/telegraf/blob/master/docs/DATA_FORMATS_OUTPUT.md
data_format = “json”
[[inputs.eventhub_consumer]]
connection_string =“****************”
epoch = 1
json_name_key = “Plant”
Hygenco Asset hierarchy
tag_keys = [“System”,“Sub_System”,“Component”]
json_time_key = “timestamp”
json_time_format = “unix”
Event hub data:
“body”: {
“Name”: “ICPro”,
“plant”: “Demo”,
“State”: true,
“Temperature”: 57,
“timestamp”: 1688713990
“enqueuedTime”: “Fri Jul 07 2023 12:43:11 GMT+0530 (India Standard Time)”
Output plugin data:
2023-07-07 12:42:50 {“fields”:{“Temperature”:24},“name”:“eventhub_consumer”,“tags”:{“host”:“Demo”},“timestamp”:1688713970}
2023-07-07 12:43:00 {“fields”:{“Temperature”:94},“name”:“eventhub_consumer”,“tags”:{“host”:“Demo”},“timestamp”:1688713980}
2023-07-07 12:43:10 {“fields”:{“Temperature”:57},“name”:“eventhub_consumer”,“tags”:{“host”:“Demo”},“timestamp”:1688713990}
The boolean tag is missing in output data.
