I recently discovered InfluxDB and it looks quite cool
As part of a PoC I’d like to use it to collect some measures of a REST API written in GO usingthe Gin Framework. Everything works well so far. To go a little bit further, I’d like to refactor from blocking to non-blocking WriteAPI.
In my REST API Server, I open one central connection to InfluxDB in my main() and inject the write/read API into my models. Close is called using the defer keyword.
I wonder when is the right/best time to call the writeAPI.flush() method, to make sure writing remains async.
Should I do that in the models (their functions are called by the handlers) when I’m done writing the points, or should I even launch a GO routine which calls it every minute or whatever? By “handlers” a mean the function that’s executed for GET calls to the server, so these are many, small calls.
