When is it necessary to configure credentials in Kapacitor
Hi
I am new in TICK. I have configured a system and when I am adding Kapacitor in Chronograf configuration, it gives the option to add user/pass to kapacitor connection. When is this configuration needed? How can I add this credentials to kapacitor?
Hello @anabel,
Welcome and thanks for your question. To get started, may I ask why it is that you want to use the TICK stack, to begin with? I would suggest getting started with Influx 2.0 instead if you’re new to Influx. 2.0 has Kapacitor InfluxDB and Chronograf integrated together, which is easier for new users.
thanks for the answer. I will try influx 2.0
