Hi ,
When telegraf is installed and configured to send data to influx, I see two From: Default and autogen.
What is the difference between these two?
Thanks,
Rishma
Hi ,
Thanks,
Rishma
@errishma This was a breaking change from older version of the database. In InfluxDB Versions less than 0.13
the default
retention policy was the DEFAULT
. In later versions of the database autogen
is the DEFAULT
. If all of your old data is in the default
retention policy, make sure you configure your telegraf clients to write to the default
retention policy by setting:
[[outputs.influxdb]]
retention_policy = "default"
Thank you Jack. This helps.
