Hello Folks,
I am trying to bring up a DB instance and write to it using a go client. The go client seems to write the data as well.
tail -f /usr/local/var/log/influxdb.log - shows a susccess code.,
[httpd] ::1 - test [23/Aug/2017:10:33:21 -0700] “POST /write?consistency=&db=rush&precision=ms&rp= HTTP/1.1” 204 0 “-” “InfluxDBClient” 28c659fb-8829-11e7-8028-000000000000 9813
However, the DB instance is empty and I don`t see any other logs or debug options to see what am I doing wrong
use rush
Using database rush
SELECT * FROM rush
DB is running on OSX 10.12.6
Where to do I see detailed logs w.r.t DB write or client event. I turned on most of the logging options via config files.
