I updated today from 1.21.2 to 1.21.3. In a Raspberry PI, no issues, but an identical config in Ubuntu brings lots of:
Feb 05 09:02:31 Camaras systemd[1]: Stopped The plugin-driven server agent for reporting metrics into InfluxDB.
Feb 05 09:02:31 Camaras systemd[1]: Started The plugin-driven server agent for reporting metrics into InfluxDB.
Feb 05 09:02:31 Camaras telegraf[4094]: 2022-02-05T08:02:31Z I! Starting Telegraf 1.21.3
Feb 05 09:02:31 Camaras telegraf[4094]: 2022-02-05T08:02:31Z W! DeprecationWarning: Plugin “inputs.io” deprecated since version 0.10.0 and will be removed in 2.0.0: use ‘inputs.diskio’ instead
Feb 05 09:02:40 Camaras telegraf[4094]: Parse module: /usr/share/snmp/mibs/ietf/DPI20-MIB:9:4: unexpected “ibm” (expected “;”)
Feb 05 09:02:41 Camaras telegraf[4094]: Parse module: /usr/share/snmp/mibs/ietf/HPR-MIB:494:30: unexpected “HprRtpCounter” (expected “}”)
Feb 05 09:02:45 Camaras telegraf[4094]: Parse module: /usr/share/snmp/mibs/ietf/SNMPv2-PDU:73:1: unexpected “max-bindings” (expected “END”)
Feb 05 09:02:46 Camaras telegraf[4094]: Parse module: /usr/share/snmp/mibs/ietf/TCPIPX-MIB:63:12: unexpected “tcpIpxConnLocalPort” (expected “}”)
Feb 05 09:02:46 Camaras telegraf[4094]: Parse module: /usr/share/snmp/mibs/miblist.txt:1:12: no match found for .
Feb 05 09:02:48 Camaras telegraf[4094]: Parse module: /usr/share/snmp/mibs/ietf/DPI20-MIB:9:4: unexpected “ibm” (expected “;”)
Feb 05 09:02:48 Camaras telegraf[4094]: Parse module: /usr/share/snmp/mibs/ietf/HPR-MIB:494:30: unexpected “HprRtpCounter” (expected “}”)
Feb 05 09:02:48 Camaras telegraf[4094]: Parse module: /usr/share/snmp/mibs/ietf/SNMPv2-PDU:73:1: unexpected “max-bindings” (expected “END”)
Feb 05 09:02:48 Camaras telegraf[4094]: Parse module: /usr/share/snmp/mibs/ietf/TCPIPX-MIB:63:12: unexpected “tcpIpxConnLocalPort” (expected “}”)
Feb 05 09:02:48 Camaras telegraf[4094]: Parse module: /usr/share/snmp/mibs/miblist.txt:1:12: no match found for .
Feb 05 09:02:51 Camaras telegraf[4094]: Parse module: /usr/share/snmp/mibs/ietf/DPI20-MIB:9:4: unexpected “ibm” (expected “;”)
Feb 05 09:02:51 Camaras telegraf[4094]: Parse module: /usr/share/snmp/mibs/ietf/HPR-MIB:494:30: unexpected “HprRtpCounter” (expected “}”)
Feb 05 09:02:51 Camaras telegraf[4094]: Parse module: /usr/share/snmp/mibs/ietf/SNMPv2-PDU:73:1: unexpected “max-bindings” (expected “END”)
Feb 05 09:02:51 Camaras telegraf[4094]: Parse module: /usr/share/snmp/mibs/ietf/TCPIPX-MIB:63:12: unexpected “tcpIpxConnLocalPort” (expected “}”)
Feb 05 09:02:51 Camaras telegraf[4094]: Parse module: /usr/share/snmp/mibs/miblist.txt:1:12: no match found for .
and never starts.
Can’t see why same configs fail in one system, not in the other … unless is not telegraf itself but some library that the update is not “updating” ?
reverting to 1.21.2, makes it work again.
Any hint about how to resolve this?
