I’m using Telegraf to collect sensor data from TTN via MQTT. All in all it works fine.
But there is one thing I do not manage.
In the data provided by TTN there is information about the gateway that has received the sensor data. There can be the situation, that more than one gateway receives the sensor data. TTN handles that and adds data for all receiving gateways in an array with gateway information. Here is an example:
"rx_metadata": [
"gateway_ids": {
"gateway_id": "eui-acxxxxxxxxxcb663",
"eui": "ACxxxxxxxxxCB663"
"time": "2024-04-30T06:11:11.383873939Z",
"timestamp": 3868520174,
"rssi": -123,
"channel_rssi": -123,
"snr": -8.25,
"location": {
"latitude": 52.0917353400241,
"longitude": 9.36717710439505,
"source": "SOURCE_REGISTRY"
"uplink_token": "xxxxxxxxx",
"received_at": "2024-04-30T06:11:11.824075916Z"
"gateway_ids": {
"gateway_id": "eui-a8xxxxxxxxx3a3c4",
"eui": "A8xxxxxxxxx3A3C4"
"time": "2024-04-30T06:11:11.822201Z",
"timestamp": 80545373,
"rssi": -37,
"channel_rssi": -37,
"snr": 13.5,
"frequency_offset": "-7155",
"location": {
"latitude": 52.1017853556478,
"longitude": 9.37492448586261,
"altitude": 60,
"received_at": "2024-04-30T06:11:11.846167537Z"
As you can see “rx_metadata” is an array that has 2 members with data for both receiving gateways.
I’m using this Telegraf configuration do move the data to an InfluxDB:
[[outputs.influxdb_v2]]
alias = "ttn_vhs_bucket_loracon"
namepass = ["ttn_vhs_loracon"]
[[inputs.mqtt_consumer]]
alias = "ttn_consumer_vhs_loracon"
name_override = "ttn_vhs_loracon"
servers = ["tcp://eu1.cloud.thethings.network:1883"]
topics = ["#"]
max_undelivered_messages = 1
[[inputs.mqtt_consumer.json_v2.object]]
path = "uplink_message.rx_metadata"
disable_prepend_keys = false
excluded_keys = ["time", "timestamp"]
As a result I get the “rx_metadata” correctly, but only the last member of that array. More precisely it is the 2nd member, since I hadn’t had the case that more than 2 gateway are receiving the data. But I thing is safe to assume, that it is the last array entry.
Do you have an advice how to handle data from all array entries in Telegraf / InfluxDB?
