I installed influxdb into the docker container and ran the docker container. After that, I proceeded with the initial setup of influxdb. After that, when I checked to see if it was saved, no data was entered into influxdb. Even using influxdb version 2, I don’t know how to save it. : (
Hello @doosan0425,
You’ll have to configure a volume.
Step 1: Pull the InfluxDB Docker Image
First, make sure you have Docker installed. Then run:
bashCopy code
docker pull influxdb
This will download the latest InfluxDB image from the Docker Hub.
Step 2: Create a Data Volume
You can create a named volume to hold the InfluxDB data. Named volumes are managed by Docker and are more convenient to work with than bind mounts.
Create a named volume:
bashCopy code
docker volume create influxdb-volume
Step 3: Run the Container with the Volume Attached
Now run a new container, and attach the volume you’ve just created. Also, expose the InfluxDB API port (usually 8086):
bashCopy code
docker run -d \
--name influxdb \
-p 8086:8086 \
-v influxdb-volume:/var/lib/influxdb \
influxdb
Step 4: Configure InfluxDB (Optional)
You might want to pass some environment variables to set up an initial user, password, and databases. Here’s how you can do it:
bashCopy code
docker run -d \
--name influxdb \
-p 8086:8086 \
-e INFLUXDB_DB=mydb \
-e INFLUXDB_ADMIN_USER=admin \
-e INFLUXDB_ADMIN_PASSWORD=admin123 \
influxdb
Step 5: Verify Installation
After the container starts up, you should be able to access the InfluxDB instance at http://localhost:8086.
What version are you using ?
Here’s another resource that might interest you
