Hi, I have started influxdb v2 on my server with docker, but I have configured the option to persist the data, but when I delete the container, the data is not persisted in my local folder.
this is my docker-compose
Hello @Miguel1,
Hmm I’m not sure. @Jay_Clifford have you ever experienced this?
Hi @Miguel1
First of all, I would upgrade to version 2.4. We did quite a bit of optimization and structural changes since then. If I remember rightly on the initial versions of the 2.0 docker container the file pathing was different. Try this example out:
influxdb:
image: influxdb:latest
volumes:
# Mount for influxdb data directory and configuration
- ./influxdb/data:/var/lib/influxdb2:rw
ports:
- 8086:8086
environment:
- DOCKER_INFLUXDB_INIT_MODE=setup
- DOCKER_INFLUXDB_INIT_USERNAME=demouser
- DOCKER_INFLUXDB_INIT_PASSWORD=demouser
- DOCKER_INFLUXDB_INIT_ORG=influxroadshow
- DOCKER_INFLUXDB_INIT_BUCKET=generators
- DOCKER_INFLUXDB_INIT_ADMIN_TOKEN=edge
