Using bash code in telegraf.conf
I’m trying to do something like this
 [[inputs.net]]
    interfaces = ["${route -n | awk '$1 ~ /0.0.0.0/ {print $NF}'}"]
$ sudo -u telegraf route -n | awk '$1 ~ /0.0.0.0/ {print $NF}'
eth0
I tried to add INTERFACE=eth0 to /etc/default/telegraf with
interfaces = ["$INTERFACE"]
And restarted telegraf, but it doesn’t work. Telegraf is run as a service.
What am I doing wrong?
You can’t use bash script within a Telegraf configuration; you can, however, use environment variables. Documentation is available here.
If you’re on Debian or Ubuntu and you’ve installed from packages or a package manager, you can put environment variables in a /etc/default/telegraf file.
If you’re using Windows, make sure that you’re using system variables and that the Telegraf user can access them.
So I put INTERFACE=eth0 in /etc/default/telegraf
And
 [[inputs.net]]
telegraf --input-filter net --test
* Plugin: inputs.net, Collection 1
> net,host=example.com,interface=all .......
What are the permissions on /etc/default/telegraf?
-rw-r--r-- 1 telegraf telegraf 16 Apr 5 09:03 /etc/default/telegraf
I’m experiencing this issue with a test VM. Let me investigate more and I’ll get back to you.
I think the issue might be that when running using --test, Telegraf doesn’t use the variables in /etc/default/telegraf. When I run Telegraf as a service I see the appropriate metrics being sent to InfluxDB.
I don’t see any data for this host if influxdb :frowning:
Though when I remove interfaces from configuration I see data coming from all interfaces.
I’m sorry, I’m not able to reproduce your issue. I am using Telegraf 1.5.2 on Ubuntu 16.04.3. Here are the steps I followed:
First, I got the interface name using the command you are using:
$ route -n | awk '$1 ~ /0.0.0.0/ {print $NF}'
enp0s3
Then I added an environment variable to my configuration. Here are the relevant lines from my config:
$ cat /etc/telegraf/telegraf.conf | grep -B 5 \$INTERFACE
[[inputs.net]]
#   ## By default, telegraf gathers stats from any up interface (excluding loopback)
#   ## Setting interfaces will tell it to gather these explicit interfaces,
#   ## regardless of status.
I added the variable to /etc/default/telegraf. Here are the contents of the file and its permissions:
$ cat /etc/default/telegraf
INTERFACE=enp0s3
$ ls -l /etc/default/telegraf
-rw-r--r-- 1 telegraf telegraf 17 Apr  5 10:15 /etc/default/telegraf
I am writing metrics to /tmp/metrics.out using the File output plugin. When I run Telegraf I see metrics for that specific interface:
$ cat /tmp/metrics.out | grep enp0s3
net,interface=enp0s3,host=scratchbox bytes_recv=175127i,packets_sent=1746i,err_in=0i,err_out=0i,drop_in=0i,drop_out=0i,bytes_sent=703715i,packets_recv=2159i 1522942350000000000
If you want to test using the --test argument, you’ll need to create and export an environment variable as follows:
$ INTERFACE=enp0s3
$ export INTERFACE
$ telegraf --input-filter net --test
2018/04/05 11:37:39 I! Using config file: /etc/telegraf/telegraf.conf
> net,host=scratchbox,interface=enp0s3 drop_in=0i,drop_out=0i,bytes_sent=775291i,packets_sent=2097i,err_in=0i,err_out=0i,bytes_recv=205727i,packets_recv=2556i 1522942660000000000
> net,interface=all,host=scratchbox icmp_outparmprobs=0i,icmp_inechos=0i,ip_fragoks=0i,ip_forwdatagrams=0i,ip_reasmoks=0i,ip_fragcreates=0i,icmp_inparmprobs=0i,icmp_outerrors= [...]
Is there any more information you can provide?
Keep in mind that when using --test, the metrics are not sent to the outputs and nothing is written to InfluxDB.
export INTERFACE with --test works for me as well.
Thanks for your time. I’ll try another approach.
I don’t know what to add more.
I try to achieve this with Ubuntu 14.04 and telegraf 1.5.3
Service is run with telegraf user
telegraf 22044     1  0 07:33 ?        00:00:05 /usr/bin/telegraf -pidfile /var/run/telegraf/telegraf.pid -config /etc/telegraf/telegraf.conf -config-directory /etc/telegraf/telegraf.d`
There is this line in init script
DEFAULT=/etc/default/telegraf
INTERFACE=eth0
If I set
interfaces = ["eth0"], data is written to influxdb
If I set
interfaces = ["$INTERFACE"], it is not
I believe the problem is how environment variables are handled with init scripts. I do not think that adding DEFAULT=/etc/defualt/telegraf to the init script will work.
When you install telegraf from our repository, it’s set up as a systemd service. You can find the unit file here. The unit file has a line, EnvironmentFile=-/etc/default/telegraf, which is how Telegraf accesses the variables in that file. Since you are not running Telegraf as a systemd service, it won’t be able to access those variables.
Here are a few StackExchange posts about using environment variables with init files. Hopefully they are helpful:
The /etc/default/telegraf file should work with the sysvinit scripts, it is sourced when they are run.
I think that Ubuntu 14.04 uses upstart though, it’s possible that it’s not working correctly with it.
Looks like if you are using sysvinit or upstart you need to export any variables you are using in the conf files:
export INTERFACE=eth0
This will be fixed in 1.6.0, you won’t need to use export.
