Input.exec not running bash script
Hi, I deployed tick stack in docker. I configured telegraf.conf file to take some metrics from [[input.exec plugin]]. Here is my bash script
#!/bin/sh
cat /proc/uptime | perl -ne ‘/(\d*)/ ; printf “%02d:%02d:%02d:%02d\n”,int($1/86400),int(($1%86400)/3600),int(($1%3600)/60),$1%60’
It is running from terminal but not from telegraf.
please help me to solve this issue
hi @pbsopankar welcome ,
it can be a permission problem ,
can you run the script with the telegraf user ?
best regards ,
Marc
yeah the script runs with telegraf user. But not from telegraf.conf it is giving an error
2019-05-10T13:54:08Z E! [inputs.influxdb]: Error in plugin: [url=http://10.195.182.27:8086/debug/vars]: Get http://10.195.182.27:8086/debug/vars: dial tcp 10.195.182.27:8086: connect: no route to host
2019-05-10T13:54:05Z E! [inputs.exec]: Error in plugin: metric parse error: expected tag at 1:12: “00:08:27:13”
This is my telegraf.conf file
[[inputs.exec]]
## Commands array
commands = [“sh /etc/telegraf/newuptime.sh”]
## Timeout for each command to complete.
timeout = “5s”
## measurement name suffix (for separating different commands)
name_suffix = “_mycollector”
## Data format to consume.
## more about them here:
## telegraf/docs/DATA_FORMATS_INPUT.md at master · influxdata/telegraf · GitHub
data_format = “influx”
Hi @pbsopankar ,
the bash script should return the output in the line protocol format …
the error : metric parse error: expected tag at 1:12: “00:08:27:13” tells that the format of the output
is not ok.
i have same issue
bash expire.sh
jks_cert,source=ESB,CN=Sattelite expire-date=1657324799
also when i ran telegraf --config /etc/telegraf/telegraf.conf test data properly writes to InfluxDB.
but if run with service telegraf status it’s showing
Jul 02 11:09:30 localhost.localdomain telegraf[10015]: 2020-07-02T15:09:30Z E! [inputs.exec] Error in plugin: metric parse error: expected tag at 1:9: "31104000"
I have the same error for my bash script too? Any idea how to resolve the same.
