What is the best method to obtain a more complete set of data from the httpjson plugin for the sub elements in a json hierarchy? For example, given the below json result how could the httpjson (or alternative) plugin provide the ability to create graphs in influx from the payload attributes “count” and “max”
{“result”:{“op”:“check”,“payload”:{“count”:“10”,“max”:“100”}},“status”:“ok”}
Which version of telegraf would support the capability and which plugin should be used?
Current version: Telegraf v1.5.2
