I have been using Influx DB 1.8 on my Windows server for several years now.
New implementations require Influx 2 , so I decided to upgrade.
Downloaded the windows 64 binary and extracted the only exe file “influxd.exe” available.
I ran it with the “upgrade” parameter as I read in the upgrade documentation.
It could not find the db path:
PS C:\Program Files\influxdata> .\influxd.exe upgrade
Error: 1.x DB dir ‘C:\Users\xeonm.influxdb’ does not exist
See ‘influxd -h’ for help
OK. I used this parameter :
PS C:\Program Files\influxdata> .\influxd.exe upgrade --v1-dir .\influxdb-data
Then it starts to copy data. However; It stops at some point.
It says the ““error”:“error copying v1 data from influxdb-data\wal\router\autogen to C:\Users\xeonm\.influxdbv2\engine\wal\7f6f4e7ca3682d3c\autogen: CreateFile influxdb-data\wal\router\autogen: The system cannot find the path specified.”,“stacktrace”:“
Here is the full output:
Setup with these parameters?
Username: admin
Organization: ice
Bucket: home
Retention Period: infinite
Yes
{“level”:“info”,“ts”:1758775247.0898995,“caller”:“upgrade/setup.go:73”,“msg”:“CLI config has been stored.”,“path”:“C:\Users\xeonm\.influxdbv2\configs”}
{“level”:“info”,“ts”:1758775247.0898995,“caller”:“upgrade/database.go:202”,“msg”:“Checking available disk space”}
{“level”:“info”,“ts”:1758775247.3810542,“caller”:“upgrade/database.go:223”,“msg”:“Computed disk space”,“free”:“160 GB”,“required”:“8.0 GB”}
? Proceeding will copy all V1 data to “C:\Users\xeonm\.influxdbv2”
Space available: 160 GB
Space required: 8.0 GB
Yes
{“level”:“info”,“ts”:1758775249.737536,“caller”:“upgrade/database.go:51”,“msg”:“Upgrading databases”}
{“level”:“info”,“ts”:1758775249.7445388,“caller”:“upgrade/database.go:101”,“msg”:“Creating mapping”,“database”:“home”,“retention policy”:“autogen”,“orgID”:“95b9dc1bc0b31724”,“bucketID”:“4f99dcab5d2e6857”}
{“level”:“info”,“ts”:1758775253.863434,“caller”:“upgrade/database.go:101”,“msg”:“Creating mapping”,“database”:“router”,“retention policy”:“autogen”,“orgID”:“95b9dc1bc0b31724”,“bucketID”:“fccf91367fb1f7ff”}
{“level”:“error”,“ts”:1758775269.5488245,“caller”:“upgrade/upgrade.go:467”,“msg”:“Database upgrade error, removing data”,“error”:“error copying v1 data from influxdb-data\wal\router\autogen to C:\Users\xeonm\.influxdbv2\engine\wal\fccf91367fb1f7ff\autogen: CreateFile influxdb-data\wal\router\autogen: The system cannot find the path specified.”,“stacktrace”:“github.com/influxdata/influxdb/v2/cmd/influxd/upgrade.runUpgradeE\n\t/root/project/cmd/influxd/upgrade/upgrade.go:467\ngithub.com/influxdata/influxdb/v2/cmd/influxd/upgrade.NewCommand.func1\n\t/root/project/cmd/influxd/upgrade/upgrade.go:157\ngithub.com/spf13/cobra.(*Command).execute\n\t/go/pkg/mod/github.com/spf13/cobra@v1.0.0/command.go:842\ngithub.com/spf13/cobra.(*Command).ExecuteC\n\t/go/pkg/mod/github.com/spf13/cobra@v1.0.0/command.go:950\ngithub.com/spf13/cobra.(*Command).Execute\n\t/go/pkg/mod/github.com/spf13/cobra@v1.0.0/command.go:887\nmain.main\n\t/root/project/cmd/influxd/main.go:61\nruntime.main\n\t/go/src/runtime/proc.go:272”}
{“level”:“error”,“ts”:1758775269.5516126,“caller”:“upgrade/upgrade.go:469”,“msg”:“Unable to remove bolt database”,“error”:“remove C:\Users\xeonm\.influxdbv2\influxd.bolt: The process cannot access the file because it is being used by another process.”,“stacktrace”:“github.com/influxdata/influxdb/v2/cmd/influxd/upgrade.runUpgradeE\n\t/root/project/cmd/influxd/upgrade/upgrade.go:469\ngithub.com/influxdata/influxdb/v2/cmd/influxd/upgrade.NewCommand.func1\n\t/root/project/cmd/influxd/upgrade/upgrade.go:157\ngithub.com/spf13/cobra.(*Command).execute\n\t/go/pkg/mod/github.com/spf13/cobra@v1.0.0/command.go:842\ngithub.com/spf13/cobra.(*Command).ExecuteC\n\t/go/pkg/mod/github.com/spf13/cobra@v1.0.0/command.go:950\ngithub.com/spf13/cobra.(*Command).Execute\n\t/go/pkg/mod/github.com/spf13/cobra@v1.0.0/command.go:887\nmain.main\n\t/root/project/cmd/influxd/main.go:61\nruntime.main\n\t/go/src/runtime/proc.go:272”}
Error: error copying v1 data from influxdb-data\wal\router\autogen to C:\Users\xeonm.influxdbv2\engine\wal\fccf91367fb1f7ff\autogen: CreateFile influxdb-data\wal\router\autogen: The system cannot find the path specified.
