I want to update the LOCATION tag from the value “DB-08” to “Main DB” for all entries. I am using the following command:
from(bucket: “power”)
|> filter(fn: (r) => r[“_measurement”] == “summary”)
|> filter(fn: (r) => r[“IP”] == “192.168.9.108”)
|> filter(fn: (r) => r[“LOCATION”] == “DB-08”)
|> map(fn: (r) => ({r with LOCATION: if r.LOCATION == “DB-08” then “Main DB” else r.LOCATION}))
|> to(bucket: “power”)
I am unable to overwrite the existing data in the same bucket, but if I change the bucket, I can create new data.
