Unable to post alert to PagerDuty2 after IP change
Hi there,
I enjoy using the TICK stack for some internal operations.
I have had it working for a few month until a recent IT change at the office.
The subnet changed from 192.168.1.1 to 192.168.15.1 and since then, kapacitor cannot post alerts to PagerDuty v2.
I can’t quite understand the error message (see below).
Configuration-wise, the whole TICK stack runs off the same machine and all binding addresses are set to “localhost”.
So I don’t quite understand this IP issue.
Can you please help?
Solution to this problem.
Even though I updated my network config in /etc/network/interfaces to adopt the new subnet, I failed to update the /etc/resolv.conf file which resulted in system-wide DNS failure and thus affected kapacitor’s ability to post to a remote API.
Before
domain ..***
search ..***
nameserver 192.168.1.1
After
domain ..***
search ..***
nameserver 192.168.15.1
run ping influxdata.com to find out if your DNS is working.
Of course, you would customize according to your own network config.
Thanks for sharing your answer @arnaudEE
