Using influxdb Cloud v2, I have set up a Deadman alert successfully and I get the slack message.
However, I would like to have the deadman status (true or false) on my board.
When I try to do the query and output it in a single stat widget, it always show the _check_id instead.
Anyone has a clue?
from(bucket: "_monitoring")
|> filter(fn: (r) =>
r["_measurement"] == "statuses"
and r["_check_id"] == "083f4bddba1ad000"
and r["_check_name"] == "test bench"
and r["_field"] == "dead")
|> aggregateWindow(every: v.windowPeriod, fn: last, createEmpty: false)
|> yield(name: "last")
