Where are the logs for your influx service ? Do they reveal anything?
Can both servers ping each other’s ip addresses?
Also, On influx server it is the receiver so you don’t need to specify the IP address, you can put 0.0.0.0:PortNumber and it will listen on any network interface
No, this is the only message in the log. The problem could come from the fact, that influx runs inside a docker container. But if I open a shell for that container I can ping the device that runs the collectd.
Since I am new to docker, I don’t know where the config file is, but I used this command to create the container, and here I am also mapping the ports for the collectd. The port 8086 is available from outside:
