I am unable to restore the database dump into influxdb docker image.
I have these files has the backup and I need to restore the data
-rw-r–r-- 1 root root 3408 Jan 7 05:22 meta.00
-rw-r–r-- 1 root root 7168 Jan 7 05:22 DCMA_Events_IIT_Oct_2019.autogen.00914.00
-rw-r–r-- 1 root root 7680 Jan 7 05:22 DCMA_Events_IIT_Oct_2019.autogen.00913.00
-rw-r–r-- 1 root root 7680 Jan 7 05:22 DCMA_Events_IIT_Oct_2019.autogen.00912.00
-rw-r–r-- 1 root root 7680 Jan 7 05:22 DCMA_Events_IIT_Oct_2019.autogen.00911.00
-rw-r–r-- 1 root root 7680 Jan 7 05:22 DCMA_Events_IIT_Oct_2019.autogen.00910.00
-rw-r–r-- 1 root root 21504 Jan 7 05:22 DCMA_Events_IIT_Oct_2019.autogen.00909.00
-rw-r–r-- 1 root root 25600 Jan 7 05:22 DCMA_Events_IIT_Oct_2019.autogen.00908.00
-rw-r–r-- 1 root root 25600 Jan 7 05:22 DCMA_Events_IIT_Oct_2019.autogen.00907.00
-rw-r–r-- 1 root root 25600 Jan 7 05:22 DCMA_Events_IIT_Oct_2019.autogen.00906.00
-rw-r–r-- 1 root root 25600 Jan 7 05:22 DCMA_Events_IIT_Oct_2019.autogen.00905.00
-rw-r–r-- 1 root root 25600 Jan 7 05:22 DCMA_Events_IIT_Oct_2019.autogen.00904.00
-rw-r–r-- 1 root root 25600 Jan 7 05:22 DCMA_Events_IIT_Oct_2019.autogen.00903.00
-rw-r–r-- 1 root root 25600 Jan 7 05:22 DCMA_Events_IIT_Oct_2019.autogen.00902.00
-rw-r–r-- 1 root root 25600 Jan 7 05:22 DCMA_Events_IIT_Oct_2019.autogen.00901.00
I am using this command to restore and I get this update
influxd restore -db DCMA_Events_IIT_Oct_2019 -metadir /var/lib/influxdb/meta -datadir /var/lib/influxdb/data /tmp/dcma_influxdb_jan_08_2020/
Using metastore snapshot: /tmp/dcma_influxdb_jan_08_2020/meta.00
2020/01/08 09:21:40 Restoring offline from backup /tmp/dcma_influxdb_jan_08_2020/DCMA_Events_IIT_Oct_2019.*
But when try to search for MEASUREMENTS I do not see any data
root@dcawinfluxdb-788d7c6454-w8c9x:/tmp# influx
Connected to http://localhost:8086 version 1.7.9
InfluxDB shell version: 1.7.9
show databases;
name
_internal
use DCMA_Events_IIT_Oct_2019
Using database DCMA_Events_IIT_Oct_2019
show
ERR: error parsing query: found EOF, expected CONTINUOUS, DATABASES, DIAGNOSTICS, FIELD, GRANTS, MEASUREMENT, MEASUREMENTS, QUERIES, RETENTION, SERIES, SHARD, SHARDS, STATS, SUBSCRIPTIONS, TAG, USERS at line 1, char 6
show MEASUREMENTS
