Hello all,
I am new here and exploring the TICK stack for performance monitoring of my systems. I have InfluxDB and telegraf installed and working fine. Next step is to get kapacitor to generate alert based on telegraf data. I have gone through the TICKScript docs and I kind of understand it.
As a start I am toying with the cpu_alert_stream.tick from examples. Installed it and enabled it. In the script I can see that
|eval(lambda: 100.0 - "usage_idle")
.as('used')
used is defined as the result of the lambda expression 100.0 - "usage_idle". I am trying to use this in my .slack() alert as
|alert()
.stateChangesOnly()
.id('{{ index .Tags "host"}}/cpu_used')
.message('{{ .ID }}:{{ index .Fields "used" }}')
.info(lambda: "stat" > info)
.warn(lambda: "stat" > warn)
.crit(lambda: "stat" > crit)
// Alert
alert
.log('/tmp/cpu_alert_log.txt')
.slack()
But slack alert shows myhost/cpu_used:<no value> as the alert text.
I checked the log file and there I can see that columns field does not have used entry.
"id": "myhost/cpu_used",
"message": "myhost/cpu_used:\u003cno value\u003e",
"details": "<snip>"
"time": "2018-01-08T14:29:00Z",
"duration": 600000000000,
"level": "OK",
"data": {
"series": [{
"name": "cpu",
"tags": {
"host": "myhost"
"columns": ["time", "sigma", "stat"],
"values": [
["2018-01-08T14:29:00Z", 1.3058797541228238, 6.069626391496513]
It would be great if some one can help me figure out why I am unable to use used
Thanks!
