Hello everyone,
last time I was following the tutorial Custom anomaly detection using Kapacitor | Kapacitor 1.5 Documentation
and met a problem that when I followed the instruction to add a config snippet in the kapacitor.conf, I found that my chronograf failed to connect to the kapacitor. I’m thinking that it may be caused by the config snippet since everything works without any problems before I add the snippet.
The error msg on the terminal said :
open service *udf.Service: failed to load process info for “tTest”: write error |1: broken pipe
I was wondering that if anyone ever solved this could give me some instructions.
Thank you very much!
