I am having input as a kafka queue which is pushing json data to influxdb. The data format is like this:
“counters”:{“0”:{“OR.E1”:{“E1SetupEstablishedCount”:“0”,“E1SetupFailureCount”:“0”}}}
where “0” is variable. So in telegraf i am converting string to int and having json_string = ["counters_*"]
So for this data sample i am getting counters_0_OR.E1_E1SetupEstablishedCount and counters_0_OR.E1_E1SetupFailureCount as columns.
Now while doing some computation and then applying map function the following error is showing: runtime error @10:6-10:86: map: failed to evaluate map function: member "counters_0_OR" with type object is not in the record
But if i am doing rename it is working fine.
I thought to remove counters_0_ so that column name can become from -
counters_0_OR.E1_E1SetupEstablishedCount to OR.E1_E1SetupEstablishedCount
still getting error: runtime error @10:6-10:74: map: failed to evaluate map function: member "OR" with type object is not in the record
Can anybody suggest me solution for this. I want atleast to retain atleast this part - OR.E1_E1SetupEstablishedCount only E1SetupEstablishedCount will not suffice.
