Since /var partition was full, I have removed all tsm files from /var/lib/influxdb/data files.
Now graphs are not available for previous ones. How to restore the old data.
Unfortunately, it appears that you have deleted the data files. Graphs are no longer available because the data used to build the graphs is all gone. Unless you have backups of the files, your data is gone.
Sorry to be the bearer of bad news.
Best regards,
dg
Hi Davidgs,
Thank you for your reply. We are using OP5 tool where performance data is stored in RRD files. Is there any way to export historic data?
Hi @madhanika,
Unfortunately I have no experience with RRD files or OP5 so I am probably not going to be able to help much here. Sorry about that.
Best regards,
dg
