Would you be able to share your data for that three day period?
This query will give you the mean of the field value for the past three days for the measurement db0.autogen.power and the tag deviceName with the value 3D Printer.
If your data if collected at regular intervals (uniformly distributed in time), then calculating the mean of the values will also give you the average power usage over time.
If your data is collected at irregular intervals, then calculating the mean of the values will not give you the expected results. As you mentioned that you had dropped values and were using fill(0), I suspect this could be a possible explanation for the results you’re seeing.
Let’s look at an example. I’m using the Influx CLI. I’ve inserted a number of values into a measurement called m1:
> select * from m1 where time > '2018-08-14T17:22:14Z' and time < '2018-08-14T17:23:20Z'
time value
2018-08-14T17:22:14.159637Z 10
2018-08-14T17:22:16.3561521Z 20
2018-08-14T17:22:18.2251241Z 30
2018-08-14T17:22:20.18086Z 40
2018-08-14T17:23:19.8976057Z 50
Since I inserted the data manually, the values are not evenly spaced. The first four occur during the same minute, while the fifth occurs nearly a minute later. I can calculate the mean of these values:
> select mean(*) From m1
time mean_value
1970-01-01T00:00:00Z 30
And we get 30, as expected. The timestamp value is the beginning of the time window for which you’re calculating the mean. But, as you pointed out before, the duration of the measurement matters to the final result. This is what those points look like on a graph:
The majority of the time is spent between the value of 40 and the value of 50; we’re interpolating linearly between those points to draw a graph. The mean over time, therefore, is probably closer to 40 than it is to 30.
We can’t take the mean of the values for a series with irregularly spaced values, but instead what we can do is break up our time range into discreet units using the GROUP BY clause. This is what our data points look like grouped into ten second intervals:
> select mean(*) from m1 where time > '2018-08-14T17:22:14Z' and time < '2018-08-14T17:23:20Z' group by time(10s)
time mean_value
2018-08-14T17:22:10Z 20
2018-08-14T17:22:20Z 40
2018-08-14T17:22:30Z
2018-08-14T17:22:40Z
2018-08-14T17:22:50Z
2018-08-14T17:23:00Z
2018-08-14T17:23:10Z 50
Because we’re potentially grouping values together, we need to provide a function for the database to apply when there are multiple values within the same window—in this case, we’re using mean(). So for the 10-second period beginning 2018-08-14T17:22:10Z, we have three values, 10, 20, and 30, and the mean of those is 20. For the next window, we have a single value, and then we have a number of windows with no value before we see the final value of 50.
We can fill in those empty windows using fill() option of GROUP BY. This is what our data looks like using fill(previous):
select mean(*) from m1 where time > '2018-08-14T17:22:14Z' and time < '2018-08-14T17:23:20Z' group by time(10s) fill(previous)
time mean_value
1534267330000000000 20
1534267340000000000 40
1534267350000000000 40
1534267360000000000 40
1534267370000000000 40
1534267380000000000 40
1534267390000000000 50
We can calculate the mean of this data using subqueries:
select mean(*) from (select mean(*) from m1 where time > '2018-08-14T17:22:14Z' and time < '2018-08-14T17:23:20Z' group by time(10s) fill(previous))
time mean_mean_value
0 38.57142857142857
There’s another caveat: the window that we choose will have an impact on our final results. What if we use a 1s window instead of a 10s one?
> select mean(*) from (select mean(*) from m1 where time > '2018-08-14T17:22:14Z' and time < '2018-08-14T17:23:20Z' group by time(1s) fill(previous))
0 38.333333333333336
Assuming that this is related to the issue you’re having, a query like this one might provide more accurate results:
SELECT mean("mean_value") FROM
(SELECT mean("value") AS "mean_value" FROM "db0"."autogen"."power" WHERE time > now() - 3d AND "deviceName"='3D Printer' GROUP BY time(10s) FILL(previous))
You will have to decide which time window and fill mode are appropriate for you.
