Thanks.I don’t think this gets me what I am looking for though. The X axis should never change, and will always be a 0-24 hours.The query should allow a user to pick a different timeframe, and then the data will be averaged from that.
This might be better served in a table. For example, I want to see the average per hour for the past 7 days.
00:00 - 10
01:00 - 23
02:00 - 30
…etc
…etc
24:00 - 12
Then if someone want to see same thing but for last 3 days, should be able to change that flag.
Hmm, not sure if I don’t fully understand you or you don’t understand me
MEAN("longest-wait-time") …and… GROUP BY time(1h) …returns mean (aka average) of longest-wait-time values during each 1 hour interval.
Then $timeFilter is a Grafana variable that stores the time interval (range)…so in you case Last x days or whatever range you select in Grafana.
So for example plain influxdb query would be: SELECT MEAN("longest-wait-time”) FROM “web” WHERE (“service” =~ /web1|app1/) AND time > now() - 3d GROUP BY time(1h), “service” fill(null)
I think I know what you mean.
So for example you’d like to get an average of all data in following ranges:
07/28 00:00:00 ~ 01:00:00
07/29 00:00:00 ~ 01:00:00
07/30 00:00:00 ~ 01:00:00
And result would be one number displayed in graph at time of 00:00:00.
If so, then yes, it is NOT possible.
Hi, did you find a solution to this? I am collecting energy consumption data to influxdb and would like to show the “today’s hourly average” with the average per hour for the last 7 days in a chart.
For the today’s hourly average I already have a continuous query but have no idea how to do it for the last 7 days.
You can achieve that with the count function.
Just use the following query:
SELECT count(“longest-wait-time”)/3600 FROM “web” WHERE (“service” =~ /web1|app1/) AND $timeFilter GROUP BY time(1h), “service” fill(null)
What happens, is that you are going to aggregate the data by 1h chunks and after you will do an average of those values.
The division value, in this case /3600 it will depend on the resolution of your database, if it is sec by sec you want the average value of 3600 data points in 1h, if it’s min by min you want the average value of 60 data points in 1h, etc…
What this does is basically calculating the hourly averages, then moves the times of all measurements to the same day and calculates the averages again. Depending on your data structure the query has to be adapted.
This would be a great feature - sounds like the USP of the way the data is stored causes this limitation in display requirement.
In principle what you @MarioG is doing is a smart way to achieve!
I only comment with a minor observation (which may be wrong as I couldn’t follow exactly what you were doing), but it looks like you may be averaging averages. If this is the case that may skew the real answer - although this slight skew would probably be acceptable for the end result.
import "date"
from(bucket: "home_assistant/autogen")
// 1. Specify the time range and filter your data
// or also
// |> range(start: -7d) // Analyzes the last 7 days
|> filter(fn: (r) => r["_measurement"] == "€/kWh")
|> filter(fn: (r) => r["entity_id"] == "current_electricity_market_price")
|> filter(fn: (r) => r["_field"] == "value")
// 2. Create a new column "hour" containing the hour of the day (0-23)
|> map(fn: (r) => ({
r with
hour: date.hour(t: r._time) // Extracts the hour from the timestamp
// 3. Group the data by the new "hour" column
// All data points for 00:00, 01:00, etc., are now in their own tables
|> group(columns: ["hour"])
// 4. Calculate the average for each hourly group
|> mean(column: "_value")
// 5. (Optional) Clean up the table for a clear result
|> keep(columns: ["hour", "_value"])
|> sort(columns: ["hour"])
|> rename(columns: {hour: "_time"})
|> group()
Then a column chart or an XY chart can be used in Grafana. Since the hour is not provided as time, normal time series charts won’t work
