Using the java client library, I am writing a POJO Measurement with multiple tags and multiple fields into a bucket using the java client library. I have no issues with writing Measurements. However when pulling back the POJOs, I can’t get the fields back.
"tag1" : "abc",
"tag2" : null,
"tag3" : "def",
"tag4" : "xyz"
"tag5" : "zzz",
"time" : "2021-05-05T15:16:07.367Z",
"doubleField" : null,
"stringField1" : null,
"stringField2" : null
Flux query… this works
from(bucket:"my_bucket")
|> range(start:-365d)
|> filter(fn: (r) => r["_field"] == "doubleField")
If I annotate doubleField into a column _value (@Column(name="_value"), I do get that field back, but not the other string fields.
thanks.
