Hello All,
Am a newbie to the TICK stack. i would like to visualize httpd processes running on my EC2 instance in Chronograh. Can someone guide me for the same?
Hello All,
@Sunil_Jacob I would start using the procstat telegraf plugin to gather the metrics. From there write the data to an InfluxDB instance (You could try an InfluxCloud Instance). Connect your chronograf to that and then you should be good to go!
@jackzampolin Thanks… Will try
