Hi guys,
I hope you can help me. I have massive problems with my influxDb.
My hardware:
- raspberryPi 3 with 16GB SD
- openHabian OS
Services:
- openhab2
- homegear
- influxDb
- grafana
I want to store a few temperature values of my openhab installation in the database. The first three or four days I had no problems. If I now want to start the influxDB with the following command I get the o.g. Error:
/ usr / bin / influxd -config /etc/influxdb/influxdb.conf
Failed to open shard: 4: [shard 4] error opening file /influxdb/data/openhab_db/autogen/4/000000134-000000001.tsm: open /influxdb/data/openhab_db/autogen/4/000000134-000000001.tsm: too many open files service = store
The only special feature is that I save the data, meta and wal folder on a network drive.
What can I do to regain my temperature readings? Where is my mistake?
ulimit -a
core file size (blocks, -c) 0
data seg size (kbytes, -d) unlimited
scheduling priority (-e) 0
file size (blocks, -f) unlimited
pending signals (-i) 7695
max locked memory (kbytes, -l) 64
max memory size (kbytes, -m) unlimited
open files (-n) 65536
pipe size (512 bytes, -p) 8
POSIX message queues (bytes, -q) 819200
real-time priority (-r) 0
stack size (kbytes, -s) 8192
cpu time (seconds, -t) unlimited
max user processes (-u) 7695
virtual memory (kbytes, -v) unlimited
file locks (-x) unlimited
