Hi, I am experiencing an issue with timestamp accuracy when writing data to InfluxDB using the Swift client (influxdb-client-swift ).
Problem:
When I write data with a fixed date in my Swift app, the entry appears shifted by 4 minutes in the Data Explorer Web Interface. I have created a simple test and can reproduce the issue consistently.
What I have tested:
- My device’s system time is correctly synchronized
- The InfluxDB server time is also synchronized (checked via NTP)
- I use
precision: .nanosecondsto avoid rounding errors
Despite these precautions, the entries remain shifted by several minutes. Could there be an automatic adjustment of timestamps by the InfluxDB client or server?
Here is my swift demo code:
var components = DateComponents()
components.year = 2025
components.month = 3
components.day = 4
components.hour = 12
components.minute = 0
components.second = 0
components.nanosecond = 0
components.timeZone = .gmt
let calendar = Calendar.current
let date = calendar.date(from: components)!
let point = InfluxDBClient
.Point(measurement)
.addField(key: "temperature", value: .double(3.0))
.time(time: .date(date))
try await influxDBClient.makeWriteAPI().write(points: [point])
Here is a screenshot from the data explorer
Any help would be greatly appreciated! Thanks in advance. ![]()
