Timeshift() does not shift correctly (or does it)?
Disclaimer: Douple post because of no answer in the InfluxDB 2 forum
Hi All,
I have the following data:
Now I want to shift that one month backwards, meaning that it starts January 1st, and then February 1st, Match 1st and so on. But if I now use:
|> timeShift(duration: -1mo)
I get the following result:
which looks like timeshift just substracts a fixed amount of days instead of a correct calendar month.
Is this the expected behaviour? If yes, what can I do the get the desired result?
Best regards,
Oliver
@Sparx82
timeShift() adds a fixed duration to time columns.
For the above scenario, you can use date.sub() to subtract a duration from a time value.
import "date"
date.sub(d: 1mo, from: 2021-03-01T00:00:00Z)
// Returns 2021-02-01T00:00:00.000000000Z
Ah thanks, this works indeed, using the map() function:
|> map(fn: (r) => ({r with _time: date.sub(d: 1mo, from: r._time)}))
Nevertheless, I think timeShift should not use fixed duration because as we all know, this duration changes over the year
