Hi All,
I have the following data:
Now I want to shift that one month backwards, meaning that it starts January 1st, and then February 1st, Match 1st and so on. But if I now use:
|> timeShift(duration: -1mo)
I get the following result:
which looks like timeshift just substracts a fixed amount of days instead of a correct calendar month.
Is this the expected behaviour? If yes, what can I do the get the desired result?
Best regards,
Oliver
Hello @Sparx82 ,
I don’t believe that is expected behavior. I think it might be a bug (depending on your version). What version of InfluxDB and Flux are you using? Do you mind exporting your data to annotatedCSV and sharing with me?
Thank you.
Sparx82
November 2, 2022, 10:52am
3
I’m using InfluxDB v2.4.0.
I investigated a little bit further and it looks like it is a problem with the timezone.
Without any timezone settings and without timeshift:
Without any timezone settings and with timeshift:
Now I add my timezone setting:
option location = timezone.location(name: "Europe/Zurich")
Please note that I have an aggreagteWindow in there, which supports the timezone as far as I know. But still strange.
|> truncateTimeColumn(unit: 1m)
|> aggregateWindow(every: 1mo, fn: first, createEmpty: true)
You can download the CSV data here:
It came from the following command:
currentvalues = from(bucket: "smarthome")
|> filter(fn: (r) => r["_measurement"] == "ElectricalEnergy")
|> filter(fn: (r) => r["Scope"] == "House")
|> filter(fn: (r) => r["Source"] == "SaiaBurgess")
|> filter(fn: (r) => r["UpdateInterval"] == "Day")
|> filter(fn: (r) => r["_field"] == "value")
|> yield()
Hello @Sparx82 ,
It could be related to:
opened 09:21PM - 13 Jul 22 UTC
enhancement
`window()` and `aggregateWindow()` window based on Unix epoch time `1970-01-01`.… It's necessary to use an offset, which is available in both `window()` and `aggregateWindow()` functions, in order to window based on the range start date.
For example, for a 30d window based on the start date, without an offset, the first window is only 7 days long:
```js
import "experimental/array"
import "date"
start_date = time(v: 2021-11-22T00:00:00.000Z)
data_raw = [
{_time: 2021-11-22T00:10:00.000Z, id: "bar", _value: 5},
{_time: 2021-11-26T00:00:00.000Z, id: "bar", _value: 10},
{_time: 2021-12-03T00:00:00.000Z, id: "bar", _value: 30},
{_time: 2022-01-05T00:00:00.000Z, id: "bar", _value: 50}
data = array.from(rows: data_raw)
|> group(columns: ["id"])
data
|> range(start: start_date, stop: date.add(d: 60d, to: time(v: start_date)))
|> window(every: 30d)
<img width="1525" alt="Screen Shot 2022-07-13 at 2 15 10 PM" src="https://user-images.githubusercontent.com/330044/178837649-51d9805f-afb4-474b-b3b9-9d06a1f7b210.png">
To window by 30 days from the start, it's necessary to add an `offset` like:
```js
import "math"
days_since_epoch = uint(v: start_date) / uint(v: duration(v: 1d))
offset = duration(v: string(v: math.mod(x: float(v: days_since_epoch), y: float(v: days_since_epoch / uint(v: 30) * uint(v: 30)))) + "d")
|> window(every: 30d, offset: offset)
<img width="1525" alt="Screen Shot 2022-07-13 at 2 17 48 PM" src="https://user-images.githubusercontent.com/330044/178838010-69aa5f09-9a52-49f8-bd6b-f6c7d9768713.png">
It would be easier if there were an option in `window()` and `aggregateWindow()` to start the windowing from the start date rather than epoch time.
