I’m using Kapacitor 1.5. I want to write rule based on last time of record in measurement. I tried following but this does not seem to be possible:
dbrp "db"."rp"
var threshold = 1h
var period = 1h
var every = 1h
var data = stream
|from()
.measurement('last_logged')
.groupBy('device-name')
|window()
.period(period)
.every(every)
|last('time')
.as('last_logged_time')
var alert = data
|alert()
.message('Device {{ index .Tags "device-name"}} has not logged in ' + string(threshold))
.crit(lambda: duration(unixNano(now()) - unixNano("last_logged_time"), 1u) > threshold)
.critReset(lambda: duration(unixNano(now()) - unixNano("last_logged_time"), 1u) < threshold)
alert
.slack()
I want to run this rule per hour. This rule is not working since last() expects a field, looks like “time” is not available as a field. Can someone suggest approach to make it work ?
I would prefer not to use batch mode since I don’t want those many queries (equal to cardinality of my data) to land on InfluxDB.
Thanks in advance!
